POS Racing
Got a little old Trane XE condenser unit. I replaced the condenser fan on it last summer and put the fan blades back at the same location on the motor shaft as it was before I took it apart. (I don't have the model number here at work, I thought I did)
Was giving it a spring cleaning last weekend and noticed when I was done the fan does not churn a nice column of air out of the center of the unit it sort of blows it out of the unit almost horizontal. I was blaming this on dirty condenser fins restricting the air but now that it is cleaned up I'm beginning to wonder.
My thought is the fan is not in the correct position so it isn't pulling the air through the condenser unit as it should. It had a fan motor replaced on it once prior to me changing the motor out last year and I'm beginning to think the fan may not have been put back correctly that time and I mimicked the location when I worked on it.
Does Trane have a spec on the XE series on where the fan should be located??
