Innovate1
For large conductors such as the run from meter to main panel or panel to garage sub panel it seems like LBs would require too small a bend radius to be allowed as well as being next to impossible to get the stiff wire into. Are the choices a 90 sweep or a box big enough to allow the needed radius? How is this normally handled when a fairly tight bend is needed like going from an outside meter base to a panel directly below it inside? There isn't enough offset for a sweep 90 unless the panel is shimmed out substantially.
