exranger06
I'm installing a subpanel in my garage. I'm going to run 2-2-2-4 MHF aluminum cable to feed my 90 amp subpanel. I'm using 1.5" RMC (yes, I know it's overkill for this application) to go down the wall from the main panel to underground. Once it's underground, I'm going to transition to direct bury. Then I'll have RMC again where it emerges from the ground and connect to the subpanel. My question is, do I need to use bonding bushings inside the panels and if so, what size wire do I use to bond? I plan on using plastic bushings on the buried ends of the conduit. Wire will be buried at least 24" deep. Is there anything else I need to know or do, or does this sound good?
