We'll be pouring concrete next week for our new detached garage I want to run (2) 2" lines of conduit from the house, 4' deep, with a 90 deg. bend turning it straight up through the concrete, so I can avoid having exposed conduit on the outside of the building, and terminate the run right at the bottom of the garage panel.
The distance between the house and garage is 32', and there will be a 4' rise to come up through the concrete.
My question is, do I need an expansion or slip joint anywhere, since one end of the conduit will be coming from the house foundation to a "floating" garage? If so, where would you put this joint? I expect to put a sleeve around the conduit where it actually passes through the concrete.
I was thinking of running the conduit fixed from the house to the 90 bend (all buried 4' deep - below frost-line), and adding a joint in the rise up through the concrete, to allow for any freeze/thaw in the ground. Is this necessary/recommended? The garage will not always be heated as of now.
Thanks in advance for any advice!
I am open to suggestions.
might make things go a little quicker. I know him well, so I called to see if he is cool with me running one for the trench. I am sure he won't care, but I just want his permission first. If I get the OK, I have a few other little things around the house I can do at the same time.
