Need to figure out the route for my conduit so I can get it in the ground sooner then I had planned. I'm burying my wood boiler water lines to the house and my electric will cross over them so I want to dig both trenches at the same time to avoid hitting my boiler lines un the future. Thinking for now I might be better off running the conduit up to the house and capping it until I'm ready to finish the job.
In the photo below, the shop is directly behind me in the photo with the pallet rack and silver tarp. I'm not sure if I would be better off running the line up out of the ground and up the wall into the attic and down to the panel. Or stay underground along the side of the house and then up to the meter/panel? I will have to cut and patch concrete either way. Up the back wall might not look as good, but less concrete to cut.
I'm currently not sure if I will be running my lines to my main panel or if I will be running to my meter and installing a new meter/panel combo outside to feed the house and shop. The main panel is on the opposite side of the wall from the meter in the photo below. The current lines are overhead so I have power now, but the new lines will be a completely new route.
What size conduit would work best for 2/0 mobile home feeder?
