jakkyl
I'm planning on adding a sub panel to my garage by routing 2-2-2-4 MHF through 2" PVC conduit from panel to panel through my crawl space.
The panel is in a small attached 'shed' and it's pretty tight in there. I originally bought a bunch of 2" PVC fittings only to realize there was no 2" knockout available on the bottom of the panel and I didn't want to go out the top or side. So, the plan right now is to use 1.5" until I'm clear and go back up to 2" after that.
My question is how do I get this conduit through to the crawl space? In the picture you will see around where I want to go through. Can I enlarge the bottom hole that already has romex going through it or do I need a separate hole for the conduit? If I have to make another hole, I'm probably going to have to remove or notch that crossing 2x4.
https://imgur.com/KqagZnw
https://imgur.com/Q3uTmSK
The crawl space is right on the other side of that wall to the left.
