I am about to wire up the lighting and outlets in my new barn, but what I cannot find on the site are examples of how conduit is run to the lighting and outlets. The trusses are 8' apart, and I dont think running the conduit perpendicular to the trusses will be good since the pipe will sag. Should the pipe be run on the bottom or side of the truss? Also, the outlets will need to be around the building with a few 220 outlets. Should the pipe go up and over, or just run it directly from outlet to outlet along the main posts parallel to the ground? Any help or examples would be greatly appreciated. Thanks!
