Conduit size /wire fill?
Toomanytools?
Washington
I am looking for what size conduit I need, I am doing some landscaping and need to bury a conduit for future use.
I have a submersible 2.5 or 3hp ( can't remember) well pump about 350' from panel. Right now it is powered by I think (4 gauge) aluminum, only 2 wires. The pump guy suggested 4 wire so either keep the 2 hots and add ground and neutral or run all new.
My question is what size conduit?
Looking at fill tables 1" sch40 will take 4, 4 gauge wires, but that seems small. The run takes a 90 out of house then straight shot to junction box at well head, so not too worried about the pull. Actually right now the wire comes out of house in sprinkler pipe for about 20' then is direct bury, which seems sketchy out in the pasture where a t-post could be pounded in.
Thanks for any insight.
alfredeneuman
Fullerton, CA
I second the vote for direct burial.
I think the smallest Mobile Home Feeder cable is #2, but that's probably the easiest and most economical way to do it.
mike93lx
Richmond, VA
How deep does a t post go? Putting the wire at about 24" should protect it pretty well.
Why do you need 4 wires? That would only be necessary if there was something 120v in the pump or pump house, if you have one .
not sure why he would do that. the pump doesnt need a neutral. but it definitely needs a ground wire.
Not in new England. The controllers are in the basement with the pressure tank. But the wire going to the pump is stranded well pump wire anyway
horrible way to do it due to voltage drop
out here in the central valley of california we put the pump controllers as close to the well head as possible. many times its on the well head...
mike93lx
Richmond, VA
Works fine. My well head was about 50 feet from the house and then the pump was 125 feet down. First pump lasted 40 years. Lots of pumps are in the 100-300 ft deep range, but the head is usually pretty close to the house. Moving the controller to the head won't do much and will subject it to the weather. It also allows not having a pump house at all.
My pump was only 1/2 hp too, so no big deal on power draw.
Blueshound_GJ
Same here in WNC.
My well here in CT is only 30 ft from the house but is a little over 500 ft deep. Works just fine with the controller in the cellar and I've never seen one outside. Does California even have cellars, or is it all slab on grade?
Norcal
Because California is not in a a god forsaken climate there is no need to dig deep footings to get below the frost line, so basements are rare, so either a raised foundation, or a slab on grade termite haven.
Blueshound_GJ
What's a termite? 😉
alfredeneuman
Fullerton, CA
What's a termite? 😉
You have said you're in CT
How common are termites in Connecticut?
Connecticut has a fairly high occurrence of termites due to its relatively mild winters and warm summers. The eastern subterranean species is the most common species to be found throughout the state.
Blueshound_GJ
Duly noted. Regardless, I don't think they are as big a problem as in warmer climates. But maybe I've just been lucky. We hijacked this thread pretty good, sorry OP lol.
yatg
Southern Oregon
My grandparents house had a cellar, bulkhead entry, dirt floor, but it was built early 1900s or before. Upscale homes in some areas have basements, more square footage on the same footprint.
Norcal
I should have said that basements are rare, but they mostly found in older homes, worked on one where the grandson of the builder told me they dug the basement with horses & team, after the floor was done it was waterproofed & they lived in there while the rest of the house was built, the wood cook stove is still there to this day, the soil is Vina loam, no rocks and easy to dig prob. some of the best dirt to be found anywhere.
alfredeneuman
Fullerton, CA
The only house I lived in with a basement the builder bought the old Corona, CA Post Office in the 1910s and rolled it 15 miles on logs with a team of mules. After 70 years of settling you could drop a marble on one end of the floor and it would roll to the other end.
Norcal
Only lived in one house with a basement back in the 60's & it was since torn down with a medical building in it's place.
