Conduit through pool enclosure: through screen or framing??
Wizzard
I need to pull a 220 run for an above ground hot tub from the main panel on the side of the house around the back corner through a screened in pool enclosure. I have two options on how to enter the pool enclosure using conduit:
1) Use a hole saw on the aluminum pool enclosure framing that mates to the back corner of the house (frame is ~3" wide).
2) Make a small hole in the screen itself right next to the frame and run the conduit through the screen.
Suggestions?
exranger06
CT
Re: Conduit through pool enclosre: through screen or framing??
Go through the framing. Going through the screen is seriously hack.
W
Wizzard
Thanks guys. I was thinking of if I ever get rid of the tub a screen patch would be easier...but then I remembered that I could just leave the 220 hookup/disconnect in place on the wall and it could be a bonus.
rharman
SoCal
If (a VERY big if) you go through the screen, at least buy a large grommet for it.
rlitman
Long Island
Can you dig it underground instead?
