bluedog225
I acquired a new conex and would appreciate some advice on condensation.
The conex will be used to hold an inverter, charge controllers, and batteries (LiFePO4). And miscellaneous storage.
Can I assume with some certainty that an air conditioned, sealed space (the conex), will not have condensation issues?
This would simplify things quite a bit.
That is, will the air conditioning remove moisture reliably? I think the answer is yes in every circumstance. Just like a dehumidifier.
The layers will be conex side, 3/4 air gap, mylar, 2” polyiso, osb, paint.
In the summer, it will be cooler than the outside air, but low humidity on the inside.
In the winter, it will be warmer than the outside air (no condensation issues).
The only thing I can think that needs attention is making sure the condensate line runs outside.
Any thoughts appreciated.
