Confused about cord plug on my "new" compressor...
lyonkster
Portland, OR
Hope someone can help me - I picked up a 40 yo 240V 20A Craftsman compressor, but am having trouble finding a way to plug it into my new garage outlet.
Here's the plug:
And here's the outlet the electrician installed for the compressor:
The outlet is a NEMA 14-30, rated for 30A, but I can't find an adapter/connector to make the compressor plug work with it.
Is there an existing adapter I can use, or do I need to modify the outlet or the plug?
sparky 1971
Central Iowa
You could use this:
and this or one like it:
Or you could make an adapter cord using a piece of 12/3 SO cord, a 14-30P, and a 6-20C
Or you could put a 14-30P on the end of the compressor cord, you won't use the terminal marked white even though there is a white wire in the cord
Or, even easier is to buy the adapter cord you posted while I was typing everything above.
L
lyonkster
Portland, OR
You could use this:
Thanks @sparky 1971. I don't feel like rewiring the outlet (got too many other projects), so I'll just wait for the adapter cord to show up at my door tomorrow (thanks Amazon overnight!).
micromind
Fernley, Nevada, about 30 miles east of Reno.
Here's the plug:
The electrician is an idiot......actual electricians know to put the ground pin up for these outlets.
L
lyonkster
Portland, OR
Amazon to the rescue! :thumbup:
TIP! Turn that receptacle so the ground is on the top……. Turn off the power before working on it.
That adapter cord needs to "hang" without being stressed.
Absolutely, I'd have to flip that outlet if I wanted to use the adapter cord. I think that if I start tinkering with the outlet, I'll just replace the 30A outlet with the 20A Leviton outlet that @sparky 1971 linked above. Cheaper, and cleaner looking, IMO.
Chuckster in NJ
Hunterdon County NJ
TRUE and easy to do!
I am NOT a fan of those adapters, just another thing that can fail plus they look amateurish.……. Do it once and do it right the first time.
L
lyonkster
Portland, OR
Don't forget about the breaker...
Thanks, I did forget about that part. Thanks for the reminder that I can't use the 30A breaker with a 20A outlet. Hmm, to swap to 20A outlet and breaker, or flip the 30A outlet and use the adapter cable.... Decisions decisions...
dave*99
Coastal NJ
I’d keep the 30A receptacle. Rotate it and use the adapter. Some folks would cut the plug off the compressor and put a 14-30P on it.
If you ever need 30A it will already be there.
mm08822
You can change the cb, BUT the hardwiring and receptacle is what determines the cb. (Welder recepts excluded.) This is where these adapters create mayhem.
It will be fine as long as the air compressor has OL protection.
N_Jay
Here's the plug:
The problem is someone put a 110v 20A plug on it instead of a 240 20A plug.
Make sure it is really wired for 220 and just remove the wrong plug and put on a correct one.
sparky 1971
Central Iowa
Nobody did that. The cord end is a 6-20P. 20 amp 250 volt.
6-20P 20 amp 250 volt:
5-20P 20 amp 120 volt:
Do you see how the horizontal prongs are opposite each other?
sparky 1971
Central Iowa
Yeah cause you'll never know when a piece of sheet metal will come sliding down the wall, into the plug and arc off because the main power is wired on the top pin???
Zim
While I am the first one to get pissed off over the ******* ground pin up/down argument, in this case the ground needs to be up because the 90° cord cap should be hanging down when plugged in. As is, the cord would be going up and gravity pulling it over towards the floor.
dave*99
Coastal NJ
Agreed 100%. And the adapter the OP proposed has a 90° plug. But if anyone wants to venture there, there is a straight 14-30P available. The Hubbell one is not cheap.
sparky 1971
Central Iowa
I've never seen a straight cap in the wild that I remember but knew they existed. If I remember, I will check pricing through the supply house. The RA cap runs about $20, the same price as the whole adapter. Flipping a receptacle 90° seems pretty simple.
dave*99
Coastal NJ
Yes, the straight plugs seem to run $60-120. Crazy. But just in case some future reader is brave enough to install a plug on a cord, but nervous to open up the box and twist the receptacle 180°, there are options albeit expensive ones.
duneslider
Riverton, Utah
Not to totally derail the post but why does the breaker need to be changed? We all have 20amp circuits in our house with 15amp outlets on them with stuff plugged in that pulls less than 15amps. How is that different than a 30amp circuit with a 20amp outlet and a device that pulls less than 20amps? Just trying to understand how this situation is different than the other? (I am not an electrician, nor do I stay at the holiday inn).
