Hi, am assembling the parts for my air supply system and despite many hours of scouring the internet, I am confused.
The plumbing solution has me stumped. Between which tubing and fittings to use, and the mixing of metals corrosion problem have me on the ropes. Advice much appreciated.
Design of system and component pics below.
The compressor currently has a 1/2" OD aluminum tubing with brass compression fittings, and ferrous metal compression nuts from the compressor head to the check valve.
The fin & tube cooler have -8AN brass inlets (37 Degree Flares). It is made out of copper tubing, aluminum fins, and a ferrous (mild steel probably) metal structural members.
My plan was to buy aluminum tubing since it is much cheaper than copper, but I read never mix the metals as the aluminum will corrode fast. OK, so then I look at spending the extra money on copper, but then I see a couple things:
Dazed and confused. Does anyone have advice on how to plumb this system?
Thank you.
PS. I know the romex wiring is improper. Was a pinch fix when building our house. When I install the air system, I will wire properly.
-Mike
- the copper I saw at the store was not 1/2" OD, it was ID.
- I look online and find 1/2" OD copper does exist, but then I see the 8AN fittings are aluminum and have 37 degree flare so it requires me to buy another flaring tool, the cheap flaring tool has very poor reviews, so the cheapest out is a $130 rigid 37 degree flaring tool for a few flares.
- So, I think, well, they used compression, so why not me too. However, I see the AN fittings show the only two options for tubing is stainless and aluminum.
Thank you.
-Mike
