Connecting 12v motor to hydraulic pump
Mgdoug3
KY
I have a project I would like to build. I have a pulling tractor and I would like to build my own water injection pump. I have a 12v electric motor that would work perfect. I can find a hydraulic for $100 to $200. I can have a cheap setup and the satisfaction of building it myself.
The problem I'm running into is connecting the two together. I can't find the adapter plate/bell housing for the electric motor. The two long bolts that connect the motor to the mounting plate is 3.5625". The OD of the motor is 4.5".
I do have a lathe and mill with DRO so I could make my own as a last resort but I thought finding a bell housing would be easy. I might have been wrong about that. Here's two pictures to help describe what I want to do better. I need to connect these two things.
larry_g
oregon
Have you found the proper splined coupling?
Have you found a mount for the pump that could be modified?
Having the mill I would make a flat plate that would mount to the motor. Then a U shaped mount for the pump that would then mount to the flat plate by bolting or welding. This doesn't have to be a fancy one piece bellhousing that is turned from a single piece of metal.
on edit, have you looked here https://www.lovejoy-inc.com/wp-content/uploads/2018/01/HydraulicPumpMotorMounts.pdf
lg
no neat sig line
Mgdoug3
KY
I have found a coupler on Ebay that will fit. That part is common to find. I'm having trouble finding a 4.5" plate with bolt hole 3.5625" inches apart.
