SprintCC
Self admitted electrical noob, it scares the crud out of me. About the only thing I know for sure is it can ruin my day.
It's my understanding that you can connect a tool that uses less amps to an outlet that provides more amps, it will only use what it needs. Connecting the other way around (pulling more amps than the outlets meant for) is asking for trouble. If so I should be able to use my 220v 15 amp compressor on a 220v 30 amp circuit. Am I understanding this right?
Starting to get my garage together after my move. The previous owner had put a 220 outlet in the garage - I've ID'd it as a NEMA 10-30 old style (3 prong) drier plug. I've verified at the box that it's hooked up to a 30 amp double breaker, & via my digital multimeter it's running 220 (actually about 250).
I have a Craftsman compressor, 220v, 15amp. It didn't come with a plug so the guy who did the electrical in my garage 2 houses ago (last time it was running) put on a NEMA L6-20 plug.
Obviously these 2 do not connect. Am I better off to:
1) attempt to find an adapter to mate the 2
2) change the plug on the compressor chord
3) change the wall outlet (I'm not even sure this is a viable/safe option).
4) give it up, get another line run.
Recommendations?
Thanks!
Chris
Recommendations?
Thanks!
Chris
