DezRanger
So I'm building a frankenstein compressor more or less and need help plumbing my new pump to my check valve in the tank. My original plan was to use a braided steel hose from the pump an run it around under the motor platform and connect it to the check valve into a 90*. Well the 90* was higher then the platform and now that wont work. So now im thinking of using a 45* on the check valve (like the pic) and using a shorter line which is less $$ then my original plan but now I run into bend radius issue
So what should be my next plan of attack? soft copper and change out all my fittings to compression?
