Marky Mark
I'm moving to a new home, pristine 450 sq ft slab, and want a glossy but reasonably priced floor. I don't mind touching up every now and then. The Legacy HD6600MMA looks ideal for my needs. Does HD6600 require acid etching?
Thanks. A couple more questions if you don't mind - I noticed the solvent-based HD6525-MMA is about the same price, is it more durable? Also, the garage will be mostly used as a light duty DIY shop, workout space, and for light motorcycle maintenance - no welding, dragging heavy stuff around, etc. How often would I likely need to recoat?
Mark
