Hi. I need some help fixing a wiring problem. I have a small shed with two doors on opposite ends/sides. Originally one light with pull chain , and an outlet on the front and back. I have already rewired so there are two lights and a 3 way switch at each door. I spaced out the outlets. There doesnt have to be one on each side, but I would prefer that, and they both need to have constant power. I also put a motion sensor light that also needs contant power. Right now power enters at first light, splits to go to second light and first switch while second switch is off the second light. I do have 3 wire between lights as well as going to each switch. Thank you for any help.
