Hi there!
I bought a house last fall with a 36x50 pole barn, concrete floor, metal roof and siding. The previous owner divided the shop into three rooms. That doesn't fit what I want to do, so this weekend I'm removing all of that and starting with an empty building.
There is no ceiling in the shop right now (the previous owner never installed one). It has trusses 5 feet on center. The ceiling height is 9'. I'll be adding stringers between the trusses to support the drywall.
I intend to drywall the ceiling. I also intend to install a single divider wall to divide the space into approximately a 30x36 space for cars/mechanical stuff, and a 20x36 space for a wood shop. I will also be studding between the posts for a wall covering (OSB probably), and will be epoxy-coating the floor. There's some wiring to do, lights to install, and insulating the walls and ceiling.
I'm going to wait until the weather is warmed up more before I do the floor. I think I want to wait until I do the floor before putting up the divider wall because I think it will be easier to coat one big room rather than two smaller ones, and it will mean the floor is coated under the wall plate, too, though I don't know if that matters at all.
I'd like to get going on getting the ceiling in, if I can, since I could then install the lights. Otherwise all the work would have to wait until the floor's coated.
Does it make sense to wait on installing the ceiling until after I have the divider wall up, or does that matter? Without the ceiling in I could build the wall and raise it in place as one piece, but I know the floor isn't level (the previous owner built it, and poured a slope in it to a drain in the floor that I wish weren't there) so building it in place (with each stud cut to length and then installed vs. building the wall and raising it in place as an assembly) isn't necessarily a great burden. I think.
What order would you all recommend I do things to keep the project moving along as much as possible? I've done just about all of the types of work that will need to be done, but this is the first project I've had where I've had to do all of this combined and I'm not sure what order makes the most sense.
Here's an interior shot of the building for reference -- demo starts this weekend
Thanks!
Thanks!
