signcrafter
- Joined
- May 9, 2012
- Messages
- 12,359
I've always had a drawer of random consumables that I've picked up over the years. some rolocs, but since they usually come in a box of 25 and aren't cheap I just have few styles/grits and use for everything. Then have some flap drum sanders for my die grinders. And some other stuff like wire wheels. But I would like to stock up and order a bunch of consumables to have and use the right ones so they last longer and have what I need when I need it.
Mainly I use them for cleaning up things like spindle bores when changing hubs, U joint yokes for new U joints, brake calipers and wheel hubs, diff housings and covers, etc.
Right now I have one or two grits of scotch brite rolocs, some of these sanding drums(https://www.amazon.com/dp/B08R2YX8WB/?tag=atomicindus08-20) and different wire wheels. I also have the 3m hub cleaning kit for going over the wheel studs to clean the hubs when doing brakes. And some other random stuff.
What roloc discs are you using and for what tasks? In other words what grits of scotch brites and sanding discs do you use for what? What other consumables are you using for different tasks? If you were going to put together a complete drawer of rolocs and other consumables to do the tasks I listed above what all would you order?
