Sounds like you are in alameda , ca so you are near san fran, sea cans should be easy to come by. you should check with your county regarding permits. stick built will need them but there may be a loop hole since the sea cans are not permanent structures, if you have close neighbors they may not like seeing them and could cause you grief. there are a ton of videos on youtube turning them into everything from shops to houses.
