Container for compressor Auto drain?
sherrod624
Sims, NC
Anyone have any ideas on a container that I could pipe my compressor drain into. It's not in a very good location to pipe outside. A 5 gal bucket full of rags? Open to ideas. I'm sure somebody's done it before.
sberry
Brethren, Michigan
Run a hose or tubing to a good place thru the wall. Mine is simply out the side, I don't have auto though but 3 vessels plumbed to the same drain, I used old copper water line, found all but 1 piece made.
sherrod624
Sims, NC
I don't have easy access to an outside wall. Also I don't run the compressor daily. Just on the weekend airing up tires and using nail guns mostly. My drain only dumps if the switch to the compressor is on.
rsanter
visalia ca
At work we use one of those 5 gal plastic fuel jugs.
The ones used for race fuel.
Hose runs into a hole in the cap
Once in a while it has to be drained
