Containing Rain/Snow/Slush in garage
Burl
Where Mountaineers are free
Winter is here, how do people contain the rain/snow brought into your garage under their cars? In my under-the-house 2 car garage, the drain is between the bays and also is the highest point of the floor. Any water runs immediately to the front drywalled wall. Any good fixes?
matt_i
Drain @ high point is not good. Break out slab and repour with proper slope.
Or, saw out & repour a new slot at the low point and figure out a way to route that water outside via gravity or pump.
krandrew
Edmonton Ab
You can use a tarp mat made for under cars. The trick is to tape down some thick rope around the perimeter (under the mat) to better contain the water. Also find a way to tape down the mat to the floor to keep it from sliding around.
lonestarky
Lindenhurst IL
Wow, can you wrap the front wall in stainless flashing? That's a problem that's not going away. Silicone seal the seam on the concrete? How about a piece of plastic deck board to protect it?
Sent from my SM-T230NU using Tapatalk
gregtwojeeps
Ky
When the public finds enough concrete contractors that actually know how to or will, ever screed the concrete to pitch to the drain(s)..... one of mankind's greatest accomplishments will be recognized. :rocker:
Many ways to cheaply and conveniently help your problem have already been mentioned, but are not permanent, hands free solutions. Your real solution will depend on your budget, your skills and how much labor you may or may not want to do. I will just mention some of the solutions I know of, and others will chime in too... ...
The home we just moved from my garage floor did the same thing, except the snow/ice water drained towards the house and went under the floor joists. So I ground the floor down, and brought the wrongly pitched floor up higher with concrete surfacer, then laid the whole one car garage with porcelain tile ....so that the water drained to the center and drained out under the 10 ft. wide garage door.
Pretty radical solution I know,it was very labor intensive and not cheap to do., but just one of many solutions. You could put in a trench drain all along your wall where the water is draining towards and then drain the water through the outside wall...where it may freeze in the pipe in the winter... unless insulated /sleeved properly...
You could grind down the whole center of the garage floor down to where it pitches to the drain. Then to hide the grinding process done... lay some sort of tile, epoxy it, or even Race Deck tile it. ...
Whatever you choose to do, you need to think about how long you intend to live in the house, and that what you do to the floor will affect the sale of the house to any prospective buyers either in a positive, or negative way. Good Luck. JMO
Burl
Thanks for the replies.....I think what I am looking for here is a type of made-up mat, something like a Weather-whatever floor mat, that you pull onto and it catches the runoff as it melts. Then when the car is pulled off of the mat and out of the garage, you **** it up with a vac. Anyone have something of this nature?
DonPowers
On The Hair At The End Of The Dog's Tail
I made a containment with used EDM rubber roofing material and a berm with 2" PVC conduit on three sides. Just tuck the edges under the conduit and you have an inexpensive containment where you can just sweep the water and slush out the door.
Check with your local commercial roofing companies to see if they will sell you some rubber sheets.
View media item 55399
View media item 55398
kbs2244
I use carpet scraps from the local rug store.
I cut the into 3 x 2 strips and let them soak up the slop.
When full they get rolled up and go to the curb, where they were headed to anyway.
