Contamination under tile flooring
hawkdriver72
I'm considering putting down tile to cover my concrete garage floor. I'm concerned about how much dirt, salt, water, oil, etc. can get under the different styles of tile. I'm planning on sealing my floor prior to installing the tiles, but have heard that items getting through the seams of the tiles can lead to odor. I'd also like to avoid taking my floor apart often. My garage floor wasn't pitched correctly and is flat, so easy draining will not happen; I'd have to rely on evaporation for standing water. I'm considering both solid and free-flow tile tops. I live in the north-east, so I have winter snow and salt to consider. Any suggestions from those dealing with the same would be greatly appreciated.
Garage Flooring
Grand Junction, CO
If you have an uncoated and unsealed floor, you could use a densifier/sealer combination such as TL39, TL021 or TrueLock B4
Armorpoxy
Hi,
We are in the Northeast and had zero reports of problems with moisture fretting trough our Supratile joints and causing problems. We are not aware that a customer has ever sealed their floor prior to instilling our tiles.
See www.supratile.com
Thanks!
