maxpower_hd
I do service work on semi-trailers and am considering a continuous duty air compressor for doing PM's or testing brakes in the yard as opposed to bringing everything to the shop to save time.
I am considering something like the one in this link. http://www.extremeoutback.com/produ...+Output+12+Volt+Compressor+Part#+007-000.html
I know it isn't meant for heavy duty repairs. I would be using it to charge the air system to test for leaks, check brake adjustments, maybe run an air impact gun to remove a couple of nuts on an air can, top off tires that sort of thing. Bigger jobs will still go into the shop and use shop air.
Anyone have something like this that can tell me if it would do the job? This one had the most CFM from the ones I have seen so far except for a military duty Oasis which was just too much money for what I want to do.
If anyone has any experience using one of these, your advice and comments would be appreciated.
Thank you.
Thank you.
