I like the idea of filling control joint prior to coating floor with epoxy. so I can have nice seamless floor but here is the concern
If control joint is filled with some solid but flexible filler so when there is movement on slab
occurs it can provide flexibility but when epoxy is applied on top of this filler, epoxy is stronger then concrete and it is bonded with concrete very well so when there is a movement it may crack since epoxy coat doesn't have flexibility same as filler inside the joints.
What do you guys think?
Scotty I know you have great 821 gel style filler but how would it address this.
Thanks in advance.
-nomogy
Thanks in advance.
-nomogy
