bc_stang
ok guys i am planning on building 14'x 30'garage starting in june.I was talking to my electrician yesterday and after going through entire house's electric load,he strongly thinks i would not have enough left over amperage to run big heaters (mr freeze,etc) as it would put me over 200amp service that i currently have. He thinks by the time i get whole shop wired for hoist,welder,compressor,extra shop lights,etc there would be no room for ceiling mounted heater box as i originally had planned to install.
What are my options here?do you think radiat heat is the way to go even in a small shop? I personally thought(correct me if i am wrong) ceiling mounted heater would heat up small shop very quick compared to in floor heat...especially in a small shop i am planning to build.
Also i should mention that garage already has its own dedicated hot/cold water supply off of main house boiler(boiler is good for 7000sq.ft house), does a shop need to have its own separate boiler system or i can use same boiler from the main house?
