dave93cab
Hi,
Sorry if this question has been posted before. I'm doing my garage up a bit, epoxy floor going in tomorrow and a paint job lined up after that Anyway..
My townhouse 2 car garage has a single bulb fitting in the center of the garage, semi-obscured by the garage door opener. Light is ok for regular use but useless if I am working on a car in the center of the garage. What I am wanting to do (and do properly) is to install some LED strips either side of the garage (minimum of 2), but I want to replace the existing bulb and use it's circuit so the light switch works etc. I'm thinking along the lines of having the existing wiring at the fitting converted into a junction box and run conduit out both ways to some LED strips mounted on the ceiling.
House is 2006 so should be modern fittings etc.
What's the correct way to achieve this following code? TX btw
Thanks
Thanks
