Dual fuel? You mean a furnace with a hrat pump AC? Usualy a heat pump will add roughly $300 to a central air system. In your location i would think you could run the heat pump very efficiently most of your heating season.
If you lease/rent your propane tank the supplier may not be happy but thats if you dont use alot of propane.
I just replaced my central air and chose not to get a heat pump unit for one reason. My primary heat is wood, wood is cheaper than a heat pump. Secondary is oil heat.
Yes--that is correct--it will use propane when the temp gets below 30 degrees, but use the electric heat pump above that.
I am paying 2.85 per gallon for propane and go through about $800 each month during the winter.
Besides thinking that Amerigas is ripping me off with their practices of "venting" the gas on fill up and filling the tank at the beginning of summer so that gas evaporates over the next few months, and refusing to fix a leaky valve, and leaving the valve open once and draining my tank, etc...(that is worth another post in itself), my unit is 22 years old.
The HVAC guys says he uses a dual fuel in his own house and it saves quite a bit of money for him.
I just don't want to take only his word for it when I can ask you GJ guys what you have experienced too.
So, it sounds like dual fuel is the way to go.
What about other upgrades? variable speed, humidifier, etc?
