Convert Ingersol Rand Compressor
PNWlost
I have two large Ingersol Rand high pressure compressors 7T2X10. Can I use parts from one i.e. cylinder heads, piston, etc to make a single standard pressure compressor.
Walkers
Cave Creek Az
You may be able to just set the pressure switch lower. The problem with those is that they pump from one cylinder to the next, to the next, with each cylinder getting smaller in order to get up to 5,000/10,000/15,000 psi. By creative replumbing you may be able to just use the primary and secondary cylinder, leaving the tertiary cylinder out of the loop, and adding a normal pressure switch.
