Converting bench grinder into a buffer
bluebolt
Benton LA
I recently picked up a Dayton USA made 10" 1hp 1725 rpm bench grinder model # 1Z853 for $20. :) It runs fine unfortunately it was dropped and the left cast iron grinder shield was badly cracked and bent to where the wheel rubs. Being cast iron it will be difficult to repair and this model has been discontinued and if they can find one that piece will be expensive. So I am thinking about turning it into a buffer since I have 3 other grinders LOL but no buffer.
So here are my thoughts.
1. Remove both shields and install Caswell "Extra long shafts" in 3/4" size, thats the shaft size on the grinder. These have 1/2" ends for the buffing wheels.
2. Use 10" (4500 SFPM (surface feet per minute) or 12" (5400 SFPM) buffing wheels to get a decent buffing speed. Suggested is 3600 to 7500 SFPM, higher preferred. With the 10" wheels I could go wider as well up to two inches wide.
3. Build a good stand that maximizes space to manuever parts for buffing, basically flat plate on top, vertical tube, bigger flat plate on bottom.
Any suggestions or comments?
back2class
yeah, it will be good. Low HP ones bog with a buffing wheel....but that will cut a shine quite well.
2oolhound
BC Canada
Tapered spindles are great but not too good for stacking wheels to get a 2" thick wheel. If you buff a variety of metals and surfaces using different compounds and wheel types the tapered is the way to go though.
930dreamer
Amarillo,TX and Stinnett,TX
I have (5) bars of Formax GREY compound? If you or any other GJ member has a use for them send me a PM.
