Converting Jenny G3s-30 fire sprinkler compressor to use as shop compressor
TrentSmith22
Olympia
Does anyone know if it is possible to convert a Jenny G3s-30 fire sprinkler compressor to a regular shop compressor? Any help would be much appreciated.
The Cobbler
Is there a tank on it? you should check to see if it has pressure ratings
I'm sure the pump will be fine, but the motor Horse power may be too low to build higher pressures . the on /off pressure switch will either have to be adjusted , but likely replaced
what sort of unloader does it use? is it part of the pressure switch?
what HP is the motor ?
LXCam
The type they use for dry systems are pretty small. I’m sure it’ll work but don’t expect too much out of it. And like cobbler said, these operate at low pressure so maybe you’ll get lucky and not need to replace the pressure switch and the unloader.
Edit; hey that’s a decent sized pump. 3hp ain’t bad and good luck.
Lassen Forge
I'd also worry about the duty cycle - it may run long enough to charge a FE tank, but I'm not sure it would maintain a normal shop tank. All in all, tho, it shouldn't take that much to rig something to try it out, and if it doesn't work, no harm, no foul.
strutaeng
Dallas, TX
Probably. Call Jenny. They are super helpful.
There's actually a human at the other end when they anwer. They know their stuff.
kaymccampbell
Upstate New York
And to reiterate, make sure that your tank is rated for the pressure you intend to use. We don't want to see your shop in the WTF thread.
LS6 Tommy
Northern NJ
Don't waste your time and money. You won't be happy with it. Preaction fire system compresors only run up to 40 Psig.
Tommy
Bert_
NW Iowa
I see the same "G" pump on their page mounted to a portable compressor. 13.8 cfm @ 100psi with a 3hp motor or 18.3cfm @ 100psi with a 5 hp motor. 125psi max.
Looks like changing a pressure switch and the motor pulley would get you a well made single stage compressor.
