I happen to have an LJ8950W and a sectional door.
Yes, I know the LiftMaster LJ8950W is designed for use with with roll up doors.
But it seems to me that unless the motor speeds are dramatically different, to convert an LJ8950W to work with a sectional door, you just need the collar for mounting it directly to the jack shaft (instead of the sprockets and chain) and the cable tension monitor.
Has anyone done this before?
Thanks!
Thanks!
