Converting motion light to an outlet
Alex-
Bay Area
Are there any tips or anything else that I specifically need to covert the following light fixture to an outlet?
I'm thinking I just need the following items:
http://www.homedepot.com/p/Red-Dot-...t-Universal-in-Use-Cover-Grey-S355E/204193183
Thanks for any feedback.
CJ7VFR
Central New Jersey
Will the box you have shown cover the entire round gang box that was installed to mount the light?
Also, where is the green screw to ground the round gang box? It is made of metal is it not?
Jim
A
Alex-
Bay Area
The hole underneath the light is about 3 inches in diameter and unfortunately the ground wire is just capped off with a wire nut and not attached anywhere.
Dustball
Hudson, WI
Be prepared to have an ugly outline of the round box showing with the new rectangle box installed. You could probably minimize that by installing a double gang box instead.
rsnip988
Elon NC
Since you are replacing a surface mount with a surface mount that should work fine.
The only difference I can see is the paint and texture difference of the round bos inprint and the smaller rectangle...
