Convince me I need a plasma cutter
Tunajoe
Ventura County
I have the opportunity to pick up a Miller plasma cutter spectrum 375 extreme for a good price.
I just recently purchased a Miller 211 MIG welder and am new to welding.
Other than cutting metal (I do have a oxy acetylene torch and rarely use it)
What would I use this for?
Any thing unique I could use the plasma for that I can't use my other torch for?
Thanks for any insight or direction.....
rhuff86
Hays, KS
Plasma cutters are invaluable in fabricating almost anything. You can make a cleaner cut than with a torch. But where it really shines is on thin material. There is much less heat distortion of the metal and a narrower kerf width allowing you to make clean cuts in body panels, and the like. A lot of people also use them for making metal art pieces because you can make nice detailed cuts.
DeadSock
Sterling, AK
Tunajoe;3580292 Other than cutting metal (I do have a oxy acetylene torch and rarely use it) What would I use this for? Any thing unique I could use the plasma for that I can't use my other torch for?[/QUOTE said:
Stainless steel and aluminum cuts
innealtoir
New England
Smaller kerf width, ability to cut nonferrous metals, no running out of gas, and you are probably going to need to look into a cnc plasma table to *really* make the experience more enjoyable! :)
Doug Arthurs
Ontario
I have a big plasma it will actually cut up to 3/4". Hardly ever use it to smokey and messy. I also seem to have a hard time making nice cuts they are often not all that straight and smooth. Mine is a hypertherm 1100. Probably just me but I wouldn't mind selling it.
arms1970
Can't cut stainless with a torch, can't cut cast iron with a torch. I should read all the replies before I reply. LOL
sberry
Brethren, Michigan
So much cleaner and cheaper to operate than a torch, reduced warpage and a couple other things you will find out once you get one.
Plombob
Tennessee
Garage Journal members do not ask such questions, grasshopper. We ask: what features, and accessories we should get with our new tool. :lol:
Charles (in GA)
50 mi south of Atlanta
Problem with a plasma cutter is you must have a supply of clean, dry, compressed air. You will need an adequate air compressor, and the electrical capacity to run both the compressor and the plasma cutter at the same time.
The clean, dry air must be extremely clean and dry, and will probably require more than the usual water separator and filter.
Other than that, everyone says its better than sliced bread. (no, I don't own a plasma cutter, but keep reading about them on here and elsewhere.)
Charles
KPSquared
Wetaskiwin, Alberta, Canada
Exactly!
The original post should have read:
"I'm buying a plasma cutter and there's nothing you can do to stop me. What do I need to make sure I buy with it so I can start using it the second I get home?"
THAT'S the Garage Journal way. . .
T
Tunajoe
Ventura County
Exactly!
Gentlemen, I stand corrected. :lol:
bcradio
New Mexico
Charles
See and I have seen quite the opposite to this... most people I have seen run no filter or dryer (just straight air) to their plasma with no problems. Clean/dry air is ideal, but far from an absolute necessity from what I've seen. You just get slightly shorter consumable life.
As for plasma's, I'd get Hypertherm over Miller as the Miller torches are made by Hypertherm, but are the previous generation. So unless it's a killer deal (i.e. used pricing) then I'd stick with the Hypertherm 30.
K13
St. Albert, AB Canada
Charles
Regular filter works fine for me.:dunno:
Jbullfrog
Avoca, Iowa
If you can get it for less than $200 do it, otherwise get a Hypertherm. The 375 has an $800 circuit board that is known to go ****. If you know how to use a torch, you deserve a better plasma than a 375. It is a sheet metal cutter, but the consumables don't like stainless or aluminum. The HT torch is way easier to cut with and can be used to shave a surface smooth.
nicksnothereman
In the Mojave
Good for exhaust work. If you don't really do a whole lot of it. Then probably okay to just use what you got.
T
Tunajoe
Ventura County
The price was $900 bucks. So maybe it's not such a deal....
I looked on Cyberweld and the were almost 1300 bucks new.
Air is no problem. I have a nice IR 80 gallon , 7.5 hp vertical compressor.
jimcolt
NH
The clean air thing is a myth that just keeps growing. Air quality for a plasma cutter is no different than you would need for paint spraying or sandblasting. In 99% of the cases....if you drain your compressor tank periodically or have an auto drain ($9.95 from harbor freight) then you will need no additional air treatment.
The other part of the myth about air for plasma cutters is that they consume a lot of air....and you need a huge compressor. In reality, a plasma that can cut 1/2" steel uses about the same air as paint spraying.....and about the same as an air impact wrench, far less than a die grinder or air sander. You can run a plasma for short bursts (20 to 30 seconds) on a tiny air compressor typically used for nail guns (3 to 4 cfm @90 psi). In 30 seconds with a good quality plasma you can cut about 120 inches of 16 gauge steel.
Good quality plasma systems from the major brands are an invaluable tool to have in your shop....incredible time savers that open up new areas of fabrication that you don't normally think of. I have not cut a piece of steel with my oxy-acetylene torches for over 30 years, just use them for heating. I sold my horizontal band saw as a hand plasma torch (Hypertherm only in my shop) can cut stock much faster than the band saw....and with a little experience (and some jigs to guide the torch with) the cut quality is very nice.
Even better.....is an air plasma cutter on a cnc machine for the best cutting capability!
Jim Colt
Charles
T
Tunajoe
Ventura County
Thank you JimColt.
I was curious if the plasma would be a substitution for other means of cutting metal, such as a band saw.
You answered that.
bcradio
New Mexico
Pass on that and save for a Hypertherm 45
jimcolt
NH
Even though I have 4 plasma cutters in my shop....I would not give up the oxy-fuel torches. There is always the need for the "smoke wrench" for loosening stuck bolts, bending a piece of metal, or straightening the piece that is not supposed to be bent. I find no need for the torches for cutting though...
Jim Colt
