Cool 1963 Couch and need for endtables
[email protected]
San Diego
This is a total farce, so no need to worry about the seriousness of the post
I have a 1963 Cadillac Sofa cut out of the rear of a real car - totally cool. I am wondering - What end tables / Coffee table should I get
So any ideas from the garage interior decorators??
Thanks
SuperSocket
Yep. You have to get blocks with glass tops as tables.
This is also a cool idea.
zjrog
Tooele, Ut
I see a use for some old brake rotors that can't be turned and still be safe... Nice.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
For two end tables you could get two crankshafts and put flywheels on the end. Use a brake rotor for the base.
For a coffee table, I'd use some pistons and rods and top it off with a glass top. Put the piston and rod upside down for the floor leg, then add a piston and rod upright attached to the other for the table support. Or use two 4 cyl. alum blocks for either two end tables or use two together to make a coffee table.
BTW....I really like the couch. Does the tailights work?
