Cool Looking Drill Press on Craigs List (I Think)
tvtaurus
Indiana
It's definitely going to need a full restoration. But I'm sure it could be put back together. I would try to get the seller down on the price.
Shiftless
East Bay SFO
I agree with 454 and the rest of you.
For reference, here is a pic of a multiple head DP set up like 454 mentioned from an auction I attended last week in Richmond CA. This rig sold for just $75. (not to me)
crguy
SW Washington
Those cast iron tables make great welding fab tables.
Carla
MEMBER EMERITUS
As has been noted, its one 'upper' from a gang-drill.
That said, the Edlund is a high quality unit, and well putting worth some work into.
I've seen several of that class of upper units turned into excellent bench drill presses by having a steel cutting firm cut out a base plate of 2" or thicker steel, which would be drilled/tapped with the pattern to mount the upper, and a pattern of tapped holes for holding-down furniture for work-pieces. Most steel-cutting firms will offer Blanchard grinding at a very reasonable price, which will make a nice job of the new base-plate.
I have an Edlund drill press of that style, myself, and, back when it was on active use in small-parts sub-contract work, I felt that the flat-belt system was safer for unskilled 'handle-pullers', as it would slip if a drill was jammed.......actually, same idea today, if I let a friend use the machine..... : )
cheers
Carla
bubinga
I'd pass, looks like it was part of a multi head setup, that someone adapted to that post. If it had the factory base it would have a lot more appeal, at least to me. Should look like this http://www.vintagemachinery.org/photoindex/detail.aspx?id=4900
Oh, Is that what they did?
Yes it would.
