Cool Monster Soldering Iron
smallcarguy
Virginia
This monster soldering iron was included in a bucket of tools I bought. I have no use for it, so I’ll probably try to sell it on ebay, or maybe in the classified section here.
But I don’t know if these are even desirable to anybody. Maybe for something like lead glass repair? It’s a massive 150w iron, nice wooden handle, and a solid copper tip that’s ½” thick, the whole thing weighs almost 1 ½ lbs. Holy cow this thing heats like it’s the surface of the sun. Made by Vulcan Electric. The Jackson model, whatever that is.
Maybe I should just hang on to it, it’s a pretty neat piece. But, I just can’t imagine what I would ever use it for. Anybody else have one like it? If so, what do you use it for?
<img src="https://lh3.googleusercontent.com/-t6LqkFMBm0k/TjM8UtJRXFI/AAAAAAAADj4/lOkUUY7-904/s800/IMG_0341.JPG" height="600" width="800" />
<img src="https://lh5.googleusercontent.com/-bvq4PTdrZvw/TjM8UGNZrDI/AAAAAAAADj0/QgH9mPf-0z0/s800/IMG_0342.JPG" height="600" width="800" />
<img src="https://lh4.googleusercontent.com/-xB9jbWzQi8c/TjM8S_BttHI/AAAAAAAADjs/5oEuuJnwA5c/s800/IMG_0344.JPG" height="600" width="800" />
<img src="https://lh3.googleusercontent.com/-P-BlDDTM4Cg/TjM8SgjhjxI/AAAAAAAADjo/_08onu-xioA/s800/IMG_0345.JPG" height="600" width="800" />
Danglerb
SoCal
Its for work like a tin smith, joining sheets etc. mechanical as opposed to electrical work.
Alchymist
Central PA
Have one similar to that - use it for soldering lugs on heavy gauge wire, like 6, 4, 2 gauge, etc. Beats an open flame, and smaller soldering irons won't do it. Plus is works great on tin. :thumbup:
BQuicksilver
I would think a smaller 150W iron would be hotter. That said I find soldering 2-6 ga stuff difficult even with a 250W gun.
smallcarguy
Virginia
ahh heavy gauge wire... that makes sense.. I didn't even think about soldering lugs on #4 or even #2. I've never done that work, but when I've been exposed to it at the BDFBs in telco central offices, its always been crimped...
Tool Pants
San Jose CA
That's a little one. Look at the tip in my hand.
2oolhound
BC Canada
My motorcycle has a wire mesh filter built into the 1 1/4" alloy oil drain plug that is held in place by a thin wire circlip. Because of the delicate location (in crankcase) the circlip must be soldered into position. That's the tool for the job. I've also used it with solder to fill corroded surfaces on small hard to find antique parts.
Danglerb
SoCal
Once you work with a big iron the practicality is obvious. Solder flows instantly with a touch even on large items, which means you can work FAST, as in production.
American Beauty is available on amazon right now, still a real and often used product.
OTOH I wouldn't use it on electrical, big current needs a crimp.
Alchymist
Central PA
Solder is fine on hi current. Problem people get into is not using heavy enough lugs or wire for the current - wire heats, melts solder. Have done 500 amps with lugs and solder with no problems. But the lugs were heavy, and the wire humongous.
