Dale1962
found this on the net.http://www.canbuilt.com/catalogue_pdf/5200.pdf thought it was cool
And the paint scheme makes it look like it was made by McDonald's.
It's a Happy Lift!![]()
My bad on the #5200, being a Mod. No.: so now the real question was done it on purpose?![]()
It's pretty neat. Seems a little lite duty at 5-800 pounds.
Thats because its probably the safe working load. Those foldable cherry pickers grunt with a 350 on them. I couldnt imagine lifting the 1ton thats printed on the arms, nor would I want to
I dont think so, It says in plain english directly to the right of the model number "for loads op to 500-800 in most applications"
Saved the PDF for the sole reason of engineering my own superior one to this...larger & more powerful...
Concept wise, I do think this is a sharp unit...performance & excecution, not so much...
I think when you bolt the two booms together is when it's rated for 5200 lbs. Looks like when you have it set up to lever compression stress on those two pivot links is when it drops the rating down to 500-800 lbs. Looks cool, but I've never found a need for a boom that stays parallel to the floor like that. And the paint scheme makes it look like it was made by McDonald's.
