Cooling system filler
Digital4n6
Glen Allen, VA
This appears to be a model that attaches to an air compressor. Any benefit of using this type instead of a Mityvac with cooling system adapters?
dodge610
North Canton Ohio
Has anyone ever ordered from this mobile distributor supply before I order from this place. Never heard of them like to find out from the group before i place an order for a few things. Thanks
ADSR
Trey T
Houston, TX
this tool is highly recommended for cars with extremely long hose cooling system; i.e. porsche 911. even on front engine cars, it helps to take the guess work out; it's a time saver, IMO.
Amphicar770
I ordered one from them. free shipping. Received a tracking number pretty quickly. Should be here tomorrow.
Spn1025
New Hampshire
Pontiac Fiero comes to mind.. what a POS car those turned out to be.
Flat-rate
What do you mean "turned out to be" they were a turd in 1984.
The cooling system was easy to fill because the thermostat was under it's own cap and easily removed to run it while the air purged.
I have the UView brand filler works great.
Spn1025
New Hampshire
I must admit though, they were "fun" to drive in the winter
dogdog
how does this thing work? in my vws they don't have a traditional radiator caps ......
Nessal
The problem with this model compared to the airlift is that this kit does not come with the universal cone shaped gasket so you can't use it on all vehicles...only the ones that the gaskets it provides. The airlift works for pretty much all cars. This is essential when trying to get out airlocks so you don't have to mess around with bleeder valves.
Nessal
You put it over the opening in the coolant reservoir and pull a vacuum. Then turn the valve handle with one end in a bucket of coolant to draw it back in. Literally turns an hour long job into a 10 minute job.
Flat-rate
Yeah because the cold temps would let it to run longer. Cracked block or blown head gasket or broken head bolt....
Only thing that never broke on a Fiero was the power steering.
