Davey4000
I have an 8 foot long section of WC281 circular waveguide (copper) that I would like to fabricate into a cooling tower coming off of my compressor. This copper tube is almost 3" in diameter. It has flanges on both ends with grooves for o-rings, which I have as well. It can easily be made air tight by bolting a piece of flat plate to each end.
My only question is how do I get air tight fittings fabricated into the flat plates on each end for the input and output of the cooling tower? I'm thinking I could weld an iron bushing into each plate, but I'm not sure about the air-tightness of the welded joint. I'm planning 3/4" input and output from the tower.
Also, provided this works, I would like a drain at the bottom of the tower. Would it be inefficient for the air supply to be coming in at the 90 degree leg of the tee with the drain coming off the straight through leg?
Ideas appreciated.
Ideas appreciated.
