No idea as we don't use UF, crappy installation in my opinion, we'd pipe it. You have to dig for either one, deeper for UF, UF will cost more money than PVC conduit and THHN.
depends on how much 1/0? 30ft? 10,000ft?
service cable? what exactly are you doing?
is that because of derating? How deep is code requirements for PVC what size for 3/0? At the time of install I would like to run PVC for video data and probable PVC (If bursts under ground I will abandon) for air but not a must any special code requirements for this?Thanks for the reply. 3/0 copperis that because of derating? How deep is code requirements for PVC what size for 3/0? At the time of install I would like to run PVC for video data and probable PVC (If bursts under ground I will abandon) for air but not a must any special code requirements for this?
Cost more but how does an individul pull 4/0 alum or 3/0 copper by himself. If its a long pull you'll need tugger, most homeowners don't have that
. I guess you like UF.
