copper air lines
mike23
I have built a new garage and I am getting ready to run air lines. I have used iron pipe in my other garage but I want to try cooper. I have searched the forum for the right solder to use. Some have used refrigeration solder containing silver. I was in Lowes and looked at thier solder. They had a solder that held 6950 psi. Would this work just as well?
FastEddieG
Chicago suburbs, IL
I've heard mixed opinions, but I think "regular" solder would work just fine. I used "silver solder" from Lowes to be on the safe side. Took a little more heat (and more time) to get the pipe hot enough, but it worked fine. Just make sure you clean the connections thoroughly and flux them well. Good luck!
-Ed
GeorgiaHybrid
Extreme NW Georgia
Mike,
I just used the recommended solder that Quincy has in their manual. They prefer iron pipe or "L" copper pipes soldered with silver solder and not lead/tin solder.
tcianci
Walpole, Ma
You will have no problems with your typical silver bearing plumbing solder. It is sold as lead free solder ususally a mix of tin, antimony and silver.
