Copper Air Piping & corrosion
rjprice
tx
Question for the hive: Do I need to insulate the mounts/hangers for my copper air piping from the the red iron & metal building purlins?
The air piping will be connected to the compressor via a rubber hose if that helps.
Thanks!
Stuart in MN
Minneapolis
Depending on how you hang the pipe it shouldn't be touching the steel anyway. If anything, isolating it will reduce vibration and noise.
R
rjprice
tx
so using copper straps to mount the pipe to a red iron h-beam will not cause corrosion? Most of my piping will be strapped to plywood but I want to mount some on the underside of a ceiling beam.
R
rjprice
tx
what type of hanger will insulate from the steel beam? most of them look copper.
K'ledgeBldr
Johns Creek, GA
I concur. Isolating to reduce vibration/noise would be my primary objective- the end result would be no electrolysis.
There are rubber insulated clamps.
LS6 Tommy
Northern NJ
The straps obviously will not cause galvanic corrosion, but the iron will. A little electical tape is fine as long as you don't have any real vibration at the contact points. We use rubber isolated clamps for copper tubing in HVAC, but You really don't have to go that nuts.
Tommy
MoonRise
One word : Plastics. :D
Plastic two (or one) hole mounting strap.
Mounts the piping and makes it so that you don't have dissimilar metal galvanic corrosion.
38Chevy454
Cincinnati, OH
You need an electrolyte (water is the typical) for any corrosion to occur. Without getting too technical, corrosion is a chemical process and it needs the electrolyte to carry the electrons. No electrolyte and no corrosion takes place.
You will be fine inside your shop.
Sent from my SM-J337V using The Garage Journal mobile app
matt_i
Look at Eaton Cooper BLine BVT series copper tube clamps, with insulating rubber insert. Its a typical 2pc strap-clamp.....which is a man-killer in its own right with sharp metal edges and a protruding fastener end just waiting to chew the unsuspecting....
bwringer
Indianapolis
There's actually little risk of galvanic corrosion between copper and steel, iron, or aluminum (although there is between zinc and copper, so it is a risk if the steel is galvanized).
I would still definitely use some sort of insulator or slightly flexible mounting so there's no chance of wear from vibration or expansion/contraction cycles. For example, as the day goes on, the walls move slightly from the heat of the sun.
It's also quite normal for the copper piping to get wet from condensation as pressure drops under heavy usage.
ericlar80
California
If your pipe builds a lot of condensation (cold air line because you are using a lot of air), then you might get some corrosion over many years. Always best to insulate if you can.
MFolks
Springfield Mo.
Hows the compressor mounted? Sitting on a pallet? Hard bolted to the floor? On end? Hockey pucks make great compressor mounts,drilled and counterbored for the bolts,should be more than enough.
Blackwolfe
Sunset MI
There is a selection of clamps at the link below to keep dissimilar metals isolated from each other. Plant that I recently retired from had dozens of strut type clamps that we replaced a few moths ago. Some were conduit lines and others were copper air and water lines. Original camps were only seven years old, but there were times when there was a lot of humidity in the facility.
One of the subs from the construction 7 years ago used the cushioned strut clamps on their part of the job connecting copper water lines to strut and those held up well with little or no corrosion.
I'm no expert, just an observation I made about the clamps.
https://www.zoro.com/cush-a-nator-c...MItbfw_JSs5AIV0hx9Ch05lQXMEAYYAiABEgKl4vD_BwE
manwithtools
Lebanon, TN
Try these, I use them more generously than steel straps clamps because they are plastic. They are pretty strong though and provide the galvanic isolation at the same time. They are also easy to use with one person as they snap closed when the pipe is inserted in the saddle.
https://www.zoro.com/nvent-caddy-superklip-tube-and-pipe-clamp-12-in-389004/i/G085799
