Copper airline installation..
Chris
Sweden
Today I have made some airline installation. It´s the first time I been working with copper tubes som some bends are not perfect. I have used only screwconnections.
I also have bought some black tube normally used for protectong cables and put over the copper tubes.
bmwpower
Looks good. I've never seen bent copper.
What are those white clips? Any close up pictures of them?
W-Cummins
Iowa
Looks nice and clean as does all your Work! Did you start with soft copper or did you anneal the hard stuff? Are thouse fittings the type that the tubes are flared 37.5° on the ends?
William...
C
Chris
Sweden
Thanks!
To bend the copper I barrowed a tool from a local shop. It looks somthing like this.
The clips are normally used in bathrooms to keep the waterpipes in place.
kartracer55
DAMN!! Thats an awesome install! Compression fittings and bent tubes! Trust me, thats some fine work youve done, very impressive, especially for your first time. Nicer than mine
Jim
C
Chris
Sweden
William...
Thanks for the nice words!
The fittings looks like this picture here below (except the colour) and I have just cut the copper pipes and the put the fittings on, works really well and I have checked all the fittings tonight and there are no airleak anywhere.
I haven´t done anything to the copperpipes and here we call them semihard pipes
automotive stud
Looks great! I was just going to post asking about doing this. Is there any link with info on the proper way to run the pipe? I remember seeing something a long time ago, about diameters, and tilting the pipe at a slight downward angle (5 degrees or something?) and putting water traps and couplers every so many feet...
kartracer55
Yeah, the link is called US!! There are a few older threads on this, look them up, they have a ton of good info
69lkmno
San Diego - Oceanside
Where can you buy those fittings?
C
Chris
Sweden
Is it this link your are looking for? http://www.sharpe1.com/dr-pipe.htm it was that side I used for planning my installation
C
Chris
Sweden
I have noticed a small pressuredrop during the night so now I am trying to find the leak. I use soapwater is there any better way? I have found 2 places already and hopefully I have fixed the leakage now.
bmwpower
Any way to isolate the sections, ie did you use ball valves?
gdf_77
farmersburg, iowa
i have yet to find a better to check for leaks. i do a lot of work with copper and the 2 shops i put copper airlines in would be extremely jealous of your shop. looks great.
C
Chris
Sweden
Thanks!
I tested a new way to find leaks. I did put a balloon over the end fittings and left them over night. In the morning I could just check which one that had air in it. I did find 2 minor leaks with this test that I didn´t find with soapwater. This morning I couldn´t see on the gauge that I have lost any pressure in the system since yesterday. Hopefully all fittings are OK now.
