Copper as a conduit?
Boyd
Forney, TX
I want to install 3 outdoor chandeliers under a new arbor we recently had built. The conduit will be exposed so I wanted to dress it up a little by using copper instead of galv steel. I don't see an issue with using copper, but I'm also not a licensed electrician.
jake26
Is painting out of the question? Even with copper, you will see the soder marks and it will petina. Painting it will keep it uniform.
Zrexxer
Pflugerville, TX
Problem I see is that there aren't going to be approved termination fittings where you tie into breaker panel, junction box, ceiling box, etc. that will work with copper. I vote for painting regular EMT.
Stuart in MN
Minneapolis
Just like how electrical conduit and fittings aren't approved for use as water pipes, copper pipe and fittings aren't approved for use as electrical conduit. So, it won't pass inspection, if that's a concern.
ishiboo
Oshkosh, WI
Run UF in it. It will be extremely hard to make any 90's with 1/2 copper, you will have to run the wire as you piece it together. It'll look cool though!
Be sure to bond the copper pipe to the ground in 1-2 places.
ishiboo
Oshkosh, WI
I think his idea of using copper is brilliant. It will last forever and look the same as when it finishes taking on it's natural green patina.
By the time you cut, prep and paint galvanized or PVC to do the same thing, you'll be at the same price... and you'll be redoing it every 2-3 years.
shoot summ
I like the idea of copper also, no need to solder the joints, I would use a 2 part epoxy so you don't have solder showing.
Thanks for the idea, I am going to steal it!
Norcal
Copper pipe is not recognized by the NEC as a conduit/ raceway.
Frank The Plumber
Chicago.
Are you trying to match a certain finish?
Will this finish age or is it sealed?
Have you tried sourcing components from a supplier of outdoor lighting fixtures?
If you have a set and sealed finish, perhaps you could contact the chandelier manufacturer, possible they have had a similar request and have a solution for you.
I think I would go with a painted and sealed conduit rather than a copper tubing.
Frank The Plumber
Chicago.
If he had unfinished fixtures I would agree, but most likely they are coated and the copper will keep going way past a match.
Boyd
Forney, TX
Wow, I didn't think such a simple, innocent question would receive so many responses. Thanks all.
To answer a few questions/comments:
Is painting out of the question? Even with copper, you will see the solder marks and it will patina. Painting it will keep it uniform.
If I go with emt I will paint it a color that matches the stained cedar as closely as possible, but I prefer the look of the aged copper. I know it’s not for everyone, but I think naturally aged copper is beautiful. Also, part of the arbor was flashed with copper sheet, it will complement the copper conduit nicely.
This is something I’ve thought of as well and is really the main reason that I’m hesitant to do it with copper.
I want it to be safe, and if I use copper I will make absolutely certain any and all joints are weather tight, but passing inspection isn’t a concern.
Didn’t think to ground it, thanks.
I planned on not soldering but was considering using a silicone glue/sealant.
And you're welcome!
djjsr
In the cornfields
For a strong and tight connection without solder there's some stuff called "Just-for-copper". Check into it. Works great.
shoot summ
It would take some work, but I think you could come up with different fittings and find ways to "copperize" a box. You could even modify fittings to work. The box wont show nearly as much as the pipe will. You could use a solder to NPT fitting to get you into the box and devise some way to secure it. If you were concerned about a reaction between dissimilar metals you could use a plastic box instead, or you could "wrap" a box in light sheet copper....
rburke65
Canfield, Ohio
ishiboo.....I have to agree with you. I think you should put up barricades and at least have someone posted near the copper pipe instalation in case the cable should fail....you don't want to get in trouble with OSHA
