dipan
The copper compressor line that I installed after a single stage pump to an aftercooler is slowly, now after several cycles, turning to a goldfish color resembling brass. I installed it with brass flare fittings and you can see the color approximating the brass fittings.
From a web search, it seems copper plus zinc and high temperature can result in brass. Is it possible there is zinc contaminating the copper or they are adding zinc because maybe it's cheaper than copper?
I don't think this will make a difference in the end because I don't plan on taking it apart and if I did, I would replace the line. The same copper used after the aftercooler does not show any similar effects. This side rarely even gets warm (the aftercooler is working very well).
Is this normal? Should I be worried?
