Copper conductors size
Gregishome
Probaly has been on topic before here but I'll just refresh the newbies electrical curiosty here. ..
I was doing some rewiring a while back in my home that was built in 1968. I took a old metal outlet box out of the wall with the 1968 vintage old 12-2 nm/g romex in it. The #12 conductor seemed stiffer than the #12 is romex now. ..
So I got out my .001 dial vernier calipers and miked the 1968- #12 and then I miked a 2012- #12 romex conductor. ...
I found a 1968 # 14 conductor and miked it in comparison with a 2012- #14 conductor. The copper #12 and #14 gauge wire made in 1968 are both larger in diameter than the 2012 romex conductors. .
larry_g
oregon
I'll bet if you mic the 2x4's you'll find the same thing. So was the cm of the wire within tolerance of what a #12 is spec'ed to be?
lg
no neat sig line
nehog
Jaffrey, NH
Post the numbers. In theory the size (diameter or square mils) has not changed, at least AFAIK!
Stuart in MN
Minneapolis
I just checked a couple of my references; one from 1960, one from 1979, and one from today. Solid copper #12 wire has a specified diameter of 80.8 mils (.0808") in all three references. Were you measuring the bare copper, or were you including the thickness of the insulation?
DekeT
USA
Is it possible that the old wires were not entirely copper?
G
Gregishome
I miked the bare copper conductor. It wasnt much difference if I recall, something like .003. Could have just been a extruder machine malfunction back in 1968 or a employee back then that was happy and said, I'll just give someone , somewhere some better wire today ! :)
eljefino
I bet there's a manufacturing tolerance that they are now better and more consistently able to come in just a hair over the absolute minimum.
