kc-steve
3-5 psi an hour loss seems to be out of the norm for most systems. Especially if it is a simple home air system.
Every time you need air you have to wait for it to pressure up and alot of unneeded wear on your motor. I have also seen some systems start to leak from a system that is pressurized and depressureized constistantly which tends to work the connections.
You could try and put a little pipe dope on your union connections to help it seal better.
Thanks for the advice. But the primary concern for the compressor is that it doesn't run too often. Pressure up time is only around 10 minutes or so. When painting I am using far more air (~6 cfm) than the 3 to 5 psi PER HOUR leakage. And like I said, I shut it down completely when I am not using it, which might be once a month maybe. Even if I leave the compressor at full pressure with the steel piping closed to the tank I still get 1 or 2 psi per hour leakage inside the compressor. In other words, if I leave it fully pressurized, disconnected from the steel pipe and unused it will still cycle once every 24 hours. It has been that way since it was new. But I'll keep that in mind and watch for a greater leakage in the future.
While in use, the compressor operates when it reaches ~100psi and shuts off when it reaches 135psi. Meanwhile my output regulators are typically set to 50psi at the compressor, 40psi at the end of the steel pipe, and 30 psi at the gun. I currently have no problems using it. But thanks anyway.
Steve
