Firebrick43
What's the best copper pipe cutter out there. I am sick of ones that don't hold up. Superior tool one not good. Like the imperial tubing cutter but it has not held up.
Imperial
I like my imperial and won't get away from them due to the groove where one can cut off small diameter jic flares. But, I have broke two of them far and I am not a tool abuser.
I like to use the ridgid 35s. it has fine threads on adjusting wheel and bearings in cutting wheel. I use it on a lot of stainless and copper tube
I'll second this, I have only used my 35S on copper, but it works great. No comparison to a "normal" tubing cutter. You get what you pay for.
For tight turning radius the Imperial Mini-Imp is good, though the NLA Chicago Specialties is better (second from the bottom on the left - if you can find one) as it covers the wheel and doesn't catch your hand skin during use.
My old straight line Imperial 127F has nice leverage for such a small cutter. It's pictured how I found it before cleaning and a new wheel.
Most of my HVAC-use ones are Imperial.
Bonneyman,and the other guys,
I have tube cutters from Ridgid, Imperial-Eastman,Rothenberger,Virax,Facom, Rems and Dako (= David Kotthaus, Germany, now living further under Gedore´s umbrella), from 4, 75 mm till 50,8mm dia. and I like them all.
One thing I learned about tubing cutters is that some manufactures have specific cutting wheels for different materials. They are consumables. So if your breaking the tools are you forcing a dull cutter to work or have the wrong cutter wheel for the material at hand. Another thing is make sure that you have the correct frame size for the dia and wall thickness of the material being cut.
You don't expect one adjustable wrench to be a whole tool kit. Don't expect one tubing cutter to do everything. You might need a few.
lg
no neat sig line
