Copper work bench - protective coatings?
superUnknown
People's Republic of British Columbia
I built a copper top workbench to do soldering and light duty stuff. Anybody with copper roof or similar have suggestions for keeping it shiny?
The whole build is here:http://www.instructables.com/id/Copper-Workbench/
garboui
Southern Ontario
Don't forget to ground with a 1M resistor in series for ESD safety. If it is going to be intended to provide ESD protection I would also worry about coatings being too insulative. An oiled or waxed film would likely be acceptable.
Bondo
Greenfield, Maine
Ayuh,.... Polish, 'n buff monthly,......
When I rebuilt the bath in my rental house, exposed plumbin' couldn't be avoided for the shower,....
I hit the copper pipin' with a ssteel wire wheel on my grinder, 'n shot 'em all with Rustoleum clear coat, enamel,....
It's been 8 years or so, 'n they're still lookin' like the day I did 'em up,....
-Brent-
Utah
Wear long sleeves and gloves. Sounds silly but the oils on your skin will "stain" the copper.
4307
Ontario, Canada
I keep my copper clean from tarnish with a half a lime sprinkled with salt, wait for salt to dissolve, rub lime on copper, wipe clean.
There are special clear coatings designed for copper, but they do not old up to high heat.
Stuart in MN
Minneapolis
Assuming you want it to remain conductive, clear coats are out. I'd use whatever it is the local tavern uses to polish their brass rails and bartops.
404
Mass
Great thing about this is that there is always a conductive path between whatever energized electrical parts might be touching the copper.
stafford
North Geogia
Look up Wenol, it's a metal polish that works so easy you won't believe it. Probably shin that whole top in 5 or 10 minutes. Works great on chrome too brass as well.
Radix2
the thumb!, MI
Maybe it is just me, but a conductive worktop for doing electrical work would be my very last choice.
it addresses low probability ESD damage by creating a high probability of shorts
